1971 Dodge Charger SE 440 Magnum Triple Black
About this Mopar:
Hello to you all,
Nice B bodies only site...
I bought this car from the original owner back in 2001 in good shape. I have made a few changes to the car as I removed the aluminum 14 inch slotted mags...ugh! Sorry, don't like the slots! Went with Crager S/S with BFG Radial T/As. The gas tank has been replaced. I removed the old offenhauser intake and finned valve covers that had been on the car since 1974 with an Edelbrock performer intake that I had powder coated, a set of chrome valve covers, Schumaker coated headers and a 3310 Holley carb.
I've just replaced the original 11 inch drum brakes with a set of A body disc brakes thanks to a lucky donor out in the local wrecker. Snagged the spindles and bought new rotors, calipers, dust shields, pads, etc... I just hope I won't have to add power assist as this thing had manual drum brakes originally. Although, someone was nice enough to replace the drum master cylinder with a disc brake MC!
I'll be replacing the Holley 3310 shortly with an Edelbrock Thunder series 800 AVS carb as soon as I save up enough points at my local Autozone!
The original owner special ordered the car as a stripped down SE with 383 mag. No power anything and manual everything! A real odd ball car, to say the least.
When he went to go pick it up they had made a few mistakes. First was a 440 mag instead of the 383 and the second one was that they had put black pin stripes on the car. Of course, I'm not complaining a bit about either one...
So, this is actually a quad black Charger!
M21 M31 N41 R35 V7X Y14
V4X U C16 C55 J52 L37
TX9 CRX9 TX9 521 075465
E86 D32 WP29 U1E xxxxxx
M21 - roof drip rails moldings
M31 - belt and hood moldings
N41 - duel exh w/o tips
R35 - AM/FM multiplex stereo radio
V7X - accent stripes (black)
Y14 - sold car
V4X - black canopy vinyl roof
U - USA
C16 - console with woodgrain paneling
C55 - bucket seats
J52 - inside hood release
L37 - concealed headlights
TX9 - exterior color black
CRX9 - black interior
TX9 - upper door frame paint black
521 - build date May 21
075465 - vehicle order no.
E86 - 440 4 bbl.370hp engine
D32 - heavy duty automatic transmission
WP29 - Charger 2 dr ht
U1E - 440 370 hp, 1971, build plant Los Angeles
15xxxx - serial number
WP29U1Exxxxxx
Item information
Category
FBBO Member Photo Garage
Added by
71Charger
Views
18,388
Comments
21
Last update
Rating
5.00 star(s) 3 ratings
Share this item
