My 1970 Plymouth Roadrunner Restoration
Hey guys, This is my photos of my restoration of my Roadrunner. I will update this periodically as I get to work on it and as I remember to take pictures (Haha!). Thanks!
About this Mopar:
Thanks for taking a look at my photo garage featuring my restoration of my Roadrunner!
Here is the stats as I know it..
VIN - RM23N0110766
It is missing the fender tag, but the vin is stamped in several spots on the car that I have found.
The quarters and outer wheel houses have been replaced prior to my ownership (not very well - badly done; will replace)
It is an original 383, auto console, bucket seat car, and the original paint color is EF8 Ivy Green Metallic.
I apparently was also sold a 727 for this project - as it turns out - it is the original 727 transmission! It has the same VIN stamped on it!
**UPDATE**
Engine bay primed..
My plan:
Mostly stock in appearance with a few custom touches. I hope you guys enjoy this build.
8/31/17
Cleaned up and blasted intake - will clear with 1k clear in very near future. Pics posted.​
9/2/17
Cleaned up rusty 440 oil pan I got for $5.​
5/26/18
Cut out the front radiator core support, straightened front inner fender metal and mocked up the new core replacement.​
6/11/20
Determined passenger inner fender metal was too damaged; cut out & replacement panel installed.​
9/02/20 to 10/20/20
FINALLY got my floor pan put in along with the passenger rear foot well pan. Had to also get a patch for the rear, that was also installed. Pics may appear out of order..​
10/31/20
Floor pan cleaned up; Weather co-operated, so I was able to get the epoxy down to seal the floor for the winter. (Included a couple more pictures from earlier as well pre-clean up.)​
3/2/21 to 3/9/21
Core support all mocked up, prepped, and welded in.​
3/16/21
Engine bay primed with epoxy.
Comments
Gotta love the availability of replacement sheet metal for our rides. I know it's rarely a perfect replacement but with some fitting and time you'll have the integrity, strength and safety back in the ole girl for years to come... good job brother :thumbsup:
Thank you for the support!
Keep up the good work! I'm just waiting on my shoulder to heal, I had to have rotator cuff surgery. I've been working on the steering column and instrument cluster.
Item information
Category
FBBO Member Photo Garage
Added by
70BeepBeep
Views
4,290
Comments
23
Last update
Rating
4.67 star(s) 9 ratings
Share this item
