64 Polara RT Magnum
Comments
RT Magnum, I'm confused? Can you also tell us more about the car please.
I guess I should have explained up front. The motor in the car is built to 440 Magnum specs. If there had been a 440 Magnum in 1964 and had they put it in a Polara, I imagine they might have called the Polara an RT.
Hi,
Very nice '64! Am I correct in assuming that that you're running manual disc brakes up front? If so, how do you like the feel? I'm leaning that way with my convertible project....
Thanks,
Steve
Hi,
Thanks,
Steve
They work surprisingly well. I wouldnt put a booster on, stops great!
Hi,
Thanks,
Steve
Glad to hear that. :) I'm doing a Max Wedge clone look motor complete with the original style MW exhaust manifolds so a booster plus the the double master cylinder [for safety's sake] really won't fit. One another question...Are you running an adjustable brake proportioning valve for your brakes, if so, where did you install it?
Thanks!
Steve
Hi,
Thanks,
Steve
Sixpaksteve,
I added some pics in this garage of the proportioning valve. Couldnt attach to this post or a PM? Not sure why...
Hi,
Thanks,
Steve
I can see the additional pics, thanks! But you didn't need an additional [adjustable] proportioning valve too? Some guys claim that they do with the manual brake setup, and they install the valve either inside of the car or in the engine bay down by the frame rail. I'd prefer not to add that adjustable valve if I don't have to. :)
Steve
Hi,
Thanks,
Steve
Sixpaksteve, no adjustable proprtioning valve on this one, have not locked the rear. No expert but I wonder if those who add an adjustable are in a race situ with slicks etc?
Hi,
Thanks,
Steve
You might be right with your racing comment. I'd rather not add that valve if I don't have to. Thanks a bunch, appreciate it!
Item information
Category
FBBO Member Photo Garage
Added by
MWFan
Views
1,923
Comments
12
Last update
Rating
5.00 star(s) 7 ratings
Share this item
