1977 Chrysler Cordoba
Photos of my Cordoba -- work in progress ;-)
About this Mopar:
More little things done ;-)
Time to clean up that Lean Burn engine wiring harness.
Currently I'm running a points distributor so I don't need much of the original harness :thumbsup:
Beautiful day for a drive in the Lowcountry! Drove about 100 miles round trip ;-)
Dual exhaust!!
More little things done! Exhaust manifolds coated. New plug wires, spark plugs, cap & rotor.
Found my broadcast sheet! ;-)
Little things done. Routine maintenance. Adding a little bling to the Doba! ;-)
Finally fixed the lower dash cover!
All done! Also installed my aftermarket tach ;-)
IMG_2975.JPEG IMG_2980.JPEG IMG_2990.JPEG IMG_2991.JPEG IMG_2604.JPEG IMG_2737.JPEG IMG_2742.JPEG IMG_2762.JPEG IMG_2761.JPEG IMG_2764.JPEG IMG_2763.JPEG IMG_2760.JPEG IMG_2612.JPEG IMG_2613.JPEG IMG_2614.JPEG IMG_2987.JPEG
Latest updates
After starting my A/C conversion 1 year ago I am finally done! So far so good! Here are some pics of my install-
Out with the old rubber trash--in with the polyurethane bushings!
So I had been putting off replacing my door strikers for a while-I knew they were worn out but sometimes little things don't seem that important until you cannot take that rattle noise anymore!
Anyways I ordered up some new aftermarket MoPar style strikers and to my surprise (as seen in second photo) were way to big-- after researching it seemed the GM style striker was the closest to what was on our Cordoba.
Sure as **** I ordered a pair of GM strikers and they fit perfectly! :rolleyes:
Comments
Nice looking engine bay. Is that duct work for a ram air system. Had that on my 73 charger. 318 motor with two to the breather.
Thanks! She is definitely a work in progress. Original air cleaner did have the cool air intake--hate to lose that ,but, I really wanted the MoPar unsilenced air cleaner.
Love that "Power Roar" at WOT!
I love the color! Glad to see the big block under the hood. Many of the Cordoba's were stripped of their big blocks and sent to the scrapper. It is nice to see you preserving this fine car. How about some interior pictures?
That's great you got the wipers going again. Where did you find the large plastic wheel that sits between the wiper linkage and wiper motor? I bought one off ebay once, but the fit was not all that great.
Actually I found a NOS motor linkage on ebay--for my car it was the best way to go as it needed everything.
Just discovered your thread... Man the 'Doba looks great! Reminds me of my 1978 Magnum with the 360 in it. A quick question, how are your door hinges? You know they are holding up some heavy *** doors ;)
All the best and keep the updates coming in.
Thank you!
You are absolutely correct about the doors--thankfully the hinges are still good! ;-)
Item information
Category
FBBO Member Photo Garage
Added by
DodgeBoy5150
Views
8,970
Comments
32
Updates
11
Last update
Rating
5.00 star(s) 9 ratings
