1973 SSP
New purchase. Exceptionally clean '73 SSP. Older repaint, 81k miles, 318, a/c, am/fm, Rallye dash, Tuff wheel, buckets with buddy seat, rear defroster. JY9 with vinyl roof.
About this Mopar:
Latest updates
rt-man
rt-man
Just swapped the Summit Racing-Holley knockoff 600cfm vacuum secondary carb for an Edelbrock 650cfm AVS2.
Its a 360, don't believe everything you see
Comments
Mods so far: changed the open differential with 2.71s to aftermarket limited slip with 3.55s. Installed OEM RR front and rear sway bars. Bought a ‘73 RR bulge hood, getting smoothed and painted. Bought a fresh ‘72 340 with ported heads, 2.02 valves, MP purple shaft cam, Torker 340 intake. Bought ‘69-70 repro 340 HP ex’s manifolds. Engine swap this Winter.
2022 update: the fresh 340 was not what it was reported to be. Went back to the drawing board and freshened up an LA 360 and put redone cast iron heads on (2.02 valves), Edelbrock 318/360 intake, 600cfm carb. A few other tweaks. Nice cruiser.
Throwing on new springs and shackles ('73 RR stock) and brake lines this Summer...
Item information
Category
FBBO Member Photo Garage
Added by
rt-man
Views
3,620
Comments
12
Updates
2
Last update
Rating
4.67 star(s) 3 ratings
More from rt-man
  • 1972 Plymouth Satellite
    Clean, 39k mile car, converted from 318/904/7.5 rearend to 440/727/8.75 rearend un-badged RR.
  • 1970 Charger R/T SE
    Numbers matching 440 4BBL, SE package including speed control. Restored to factory specs.
Share this item
