1966 Plymouth Belvedere
Just my home garage with one Mopar.
About this Mopar:
408 stroker (LA 360 w/ Magnum closed chamber heads)
2.02/1.60 valves, mild porting
Comp Cams Nostalgia Purple Plus cam (PN #20-670-4 [94])
Scat 4" stroker crank and rods
Kieth Black flat top pistons
9.7:1 comp
Hughes Engines 1.65 ratio stainless steel roller rockers
Hy-Lift Johnson hydraulic race lifters
Edelbrock RPM Air Gap intake
Edelbrock Thunder AVS 650 carb
MOPAR electronic ignition
Hooker Super Comp Headers
Flowmaster Series 40's and 3" X-Pipe exhaust, turn downs at rear tire
Keisler RS 5 speed
Wilwood hydraulic clutch conversion
355 Sure Grip
Comments
Item information
Category
FBBO Member Photo Garage
Added by
AZBelvedere
Views
1,722
Comments
3
Last update
Rating
5.00 star(s) 3 ratings
More from AZBelvedere
  • 1966 Plymouth Belvedere
    408 stroker (LA 360 w/ Magnum closed chamber heads) 2.02/1.60 valves, mild porting Comp Cams...
Share this item
