“ Gimmie A BRAKE …… NEW FROM JEGS !
dodgeboy440
BOHNALITE CHRYSLER HEMI PROTOTYPE 1951
11:05 PM
las vegas nevada
JEGS Automotive Supply
NEW
MOPAR Brake Setup !
Check it out !
In the sea of brand X Jegs stands tall
And brings to market a reasonably priced
Power brake setup !
Kudos to them !
Now Buy One IF You Need One!
Mopar2ya!!
John
NEW
MOPAR Brake Setup !
Check it out !
Power brake setup !
Kudos to them !
Mopar2ya!!
John
I never like seeing that GM-looking booster and master cylinder on a Mopar. Just my opinion.
Yah great, now you can install yet another Janky looking Chevy master cylinder mounted via a bunch of cheap CNC punched out linkage arms attached to a power booster that juts out way to far into the engine bay.
No thanks
Certain things fit certain needs. ( Edit: some utilize GM HEI ignition for their Mopar engines. ) Unless you seek complete originality, function prevails over appearance in many cases.
You Sir are Emminently Entitled to you’re
Opinion !
I invite you to Design & Bring To Market
A Product That Meets You’re Specifications!
Then The “ Men Of Mopar “ can have more choices !
Great idea Eh!
Mopar2ya!!
John
Leeds has exactly what I want. I should have bought the kit when it was $900. Now $1400.
Guess I'll just fix my drums. Already have all the parts.
Carpe Diem !
I believe we’ve all been “ in the shoulda woulda coulda “ clan at one time or another!
Hindsight is 20/20 !
Mopar2ya!
John
I converted my '64 Polara to front disc brakes in 1982, long before any Mopar magazines were writing articles on it, and before some of our members were born. Of course, parts from junk yard donor cars were a lot easier to find, back then. Proper looking Bendix boosters are being reproduced, as well as bracketry for a more original look. Original style master cylinders are still available from parts jobbers, or RockAuto. When I see the aftermarket GM-looking setups on a Mopar, it just screams, " I don't care! ", because it can still be done with appropriate appearing parts. It just takes a little more sourcing, instead of one stop shopping.
There are similar setups and part combos that look much more like the Hemi/A body power booster setup, and also have 4 bolt master cylinder mounts.
Some are even $100 cheaper.
The first kit uses a GM Master Cylinder but a CPP booster.... Probably ten years ago maybe more I got involved in working on a 70 Challenger that had a CPP booster on it... It didn't work... I got it swapped under warranty... The new one didn't work... I double & triple checked my diagnosis... The new booster was definitely bad.... Swapped it again... Still nothing... Would up talking with a friend that owns a Street Rod fabrication shop... He tells me they won't sell or service CPP boosters, They sold them for about four months, more failed boosters than working boosters.... He wound up replacing every CPP booster for his customers on his dime cause he didn't want his name associated with their product...
I installed a rebuilt Bendix booster & solved the customers problem...
My 69 RR converted to power brakes. Set up from Pirate jacks.
Hope it will clear the air grabber unit?
Manual brakes converted to disc fronts on my 65 Coronet. Another Pirate Jacks unit. this one
does not need the pressure reducer for the rear.
