0ne owner 1967 GTX restoration
Looks fantastic, but why is the trans crossmember mounted upside down?
Good eye! The guy at the shop just bolted it on upside down. He never worked on older cars. We finished the engine install and started it up at around 3 this afternoon. It cranked up on the first try! That electronic ignition was put on the car back in 1978 and that is the same control unit and distributor we bought from Chrysler to replace the dual point that the four speed cars came with. I almost put it back in but the electronic is a good upgrade tor the way I will use the car.
Here are some from today. Rear brakes, new lines, rear wheel bearings and seals, front shocks.
Thanks RoadRunner. I was wondering if anybody was still out there! I got the new brake lines and brakes on. The body is buffed and next week I can hang the front sheetmetal and finish the sanding and polishing. Then the dash, steering and glass go back in.
It moved on its own power this week. First time since March. Glad to have it back on all fours!
Here is the latest pictures. Got the doors, fenders and hood on. The wheel covers cleaned up pretty good. That is the original set that came on the car.
It is but I could not find it in a charcoal only in silver that was on the first picture of the tail panel. I sprayed it and then used a x acto knive to scrape off the paint in the area of the PLYMOUTH lettering.
Here is a picture from today. I sanded and buffed it and drove it outside. The other picture is from March.
Going to put the headliner in and get the front end aligned next. The only thing I have left to do is finish!
Got the headliner and windshield installed
Headliner. Some wrinkles but they should fall out, I hope.
Here is the list so far:
Radiator clean and repair
Hoses and clamps
Gas tank
Sending unit
Fuel Pump
Fuel Filter
Weatherstrips door, trunk, upper door frame
Carburator Carter AFB #4326 restored
Choke thermostat
Body plugs
Body bumpers
Under hood straps
Battery Cables Positve and Ground
Engine Ground Strap
Fuseable Link
Carpet
Headliner
Master cylinder
Clutch
Camshaft
Lifters
Timing chain and gears
Oil Pump
Harmonic Ballancer
Rocker arm shaft and rocker arms
Valve stem seals
Alternator
Starter
Brake lines
Brake shoes and hardware
Brake hoses
Wheel Cylinders
Batery hold down
Balast resistor
Decals: Antifreeze, tire pressure, jack instructions, air cleaner service
Cat wiskers
Bearings main and camshaft
Rings
Freeze plugs
Voltage regulator
Firewall gaskets
Door handle gaskets
Engine gaskets
Ball joints
Tie rod ends
Upper and lower control arm bushings
steering shaft swivel kit
Sway bar link bushings
Fuel tank filler hoses
Talilight lens
Seat belts
Lower chrome moulding roof to quarter panel
Horn rim
Air cleaner and filter
Front shocks
Front wheel bearings
Rear axle bearings
Torsion bars
Trunk mat
Trunk divider
Spare tire cover and hold down
Spare tire 7.75 x 14 Goodyear Power Cushion redline
Jack
Transmission seals and bearings
Throw out bearing
RR wheel lip moulding
Quarter panel patch right
Acid etch primer
Primer Surfacer
Single Stage paint
Clearcoat
Dye for Headliner
Paint for Dash and steering column and interior trim
POR 15 for K frame
Soda Blasting of body trunk and under hood
Floor pans, partial
Wheels and red line tires
Interior windshield trim
Rocker Moulding clips
Windshield
Windsheld seal
Back glass
Back glass seal
Mldg clips
Rear bumper seal
Windshield washer t and bottle
Hood seal
Cowl seal
Windshield wiper seals
Clutch linkage service kit
Shifter clips
Electronic Control Unit
Coil
Spark Plug Wires
Spark Plugs
Oil Filter
Still need list is getting shorter:
A frame seals
Seats covers and foam
Buddy seat cover
Bumpers chromed
Exhaust system
Exhaust tips
Interior trim chromed
Dash bezel and glove box door chromed
Instruments restored
Back up light lens
Rear shocks
Distributor cap Tan
Headlights and adjusters
Arm rest bezels
Inside door handles
Window cranks
Sill plates
Would like to have:
Mopar battery
Date coded ignition wires
Belts and hoses “mopar”
Anti theft screws for gas cap
