FOR SALE 1/2 Dozen 426 Blocks
GTX JOHN
9:33 AM
Boulder City, NV.
Feedback: +104 / =0 / -1
These all came out of Tri City Performance. Greg Luneack (RIP) was a close friend
and one of the very top Max Wedge engine builder and National Event winning
Max wedge Stock/SS racers of the last several decades. He had a complete machine
shop on premises and did all work himself. He is truly much of the reason for my success over
these many years!
One 426 Unique Block. It is Standard Race/Industrial/Nascar?
factory set up for 4 Bolt Mains and lots of extra webbing and features
It is very very heavy compared to the other blocks, VERY RARE!!
See Discussion of this in Racers Hangout in both A/B today.......................$1,250.
Several 426 Standard Production Blocks...................................................$750.Each
One 440 .030........................................................................................ $650.
Two 413 Standard (I cannot get to it yet to see Industrial) .......................$400.Each
One 1963 Bare 426 Max Wedge (286) Head..............................................$475.
He has Acid Washed/HotTanked Magged and Pressure/Sonic Tested nearly
all of the blocks prior to putting them in inventory to be built by his shop. That
work alone has often cost me $400 to $500 anymore = now that
he is deceased.
Several Full Race prepared 426 blocks built for stock or Superstock.
Bushed Lifter Bores/Decked on C/L. Bored With deck plate with
hot water flowing. Partially filled with Block Hard/Main Studs They are his
personal engines as I understand for one of his cars and I am
selling them for less than the machine work costs = let alone finding
a 426 block that Sonic tests well enough for competition....................................$1,950.Each
One used 426 plus 030 used Short Block. 1963 Model Year car AAQA Block.
11 to 1 TRWs. Solid Max Wedge Camshaft/Lifters. Timing Chain/Cover.
Less Head/Intake/Carbs............................................................................$1.500.
One matched Pair of 3705SA 1964 Max Wedge Carbs off one of his A/SA cars.
I will check them out and take apart for inspection and assemble.
I will replace needles and seats and Accel pumps as needed
One of the does not have a legible # but the are identical 3705SA..................$750.pr.
These are not my stuff and that is all I know about this stuff.
That is why they are way less than I would ever sell my personal
stuff!!
These parts are in my trailer at my shop and I am the Seller.
This stuff is right by the trailer door and I will dig out many other
parts further back when I am able to do so.
I get to So Cal and could deliver for free.
Also will deliver to Nevada (Free in South Nevada) and Arizona
for the cost of Diesel.
Sorry for the misposting.
My vision is very imparted currently until
next couple of surgeries after XMAS.
I know better = just cannot see to read very much currently.
Do you have any inventory of the parts, or did you just load the trailer for a price? I'm sure you probably posted the main items. I'm looking to build another engine, just not sure which direction I want to go, other than it will be a big block Mopar.
I just loaded everything in the shop into the trailer and my Dually. We
only had a couple of Hours to move all this stuff. It was a very difficult
time for all of us.
The complex financial arrangements between us involved Real Estate/Truck
and Trailer and parts.
They will remain private between us.
Actually, I just posted a few things closest the rear trailer door that
my son could get to with his phone to take pictures. There are hundreds of
other items that Greg accumulated over his 78 years in the truck and trailer.
Anxious to here what all you have. I did see a few cranks, and other items. Thanks for the reply.
these many years!
he is deceased.
stuff!!
Sent you a PM. Thanks, Scott in SC
I will,
I believe the two standard 426 blocks are 230 numbers.
The other standard 426 Block that has the ribs and 4 Bolt provisions
does not have a number on it of any kind.
I had it looked at by one of the very top 426 Max Wedge racers currently in
both NHRA stock and superstock. He is also a noted engine builder as well.
Here is what he said for what it is worth:
"When Chrysler cast the 426 Wedge blocks for NASCAR
the first run of castings produced, they also cast some of the blocks for Industrial
HD use without the four bolt mains installed but with provisions for them. Otherwise
they are totally identical to the NASCAR blocks".
These are quite rare to find and extremely desirable for Stock and Superstock racing or
any other racing where you are limited to OEM two bolt configurationdue to
the unique thickness of the cylinders/Deck.
It should be a bargain for $1,250.
r
I could use the 730 and/or 230 block an noted previously, but curious who the max wedge racer/engine builder is who valued the industrial blocks. I will say that 'industrial' does sound 'strong' in terms of longevity, though!!
In my opinion he is the absolute top Stock/SS Max Wedge Racer
currently active in both classes. He is a buddy of mine. However, I
do my very best to not involve my friends is my personal business.
In my experience (Started Racing Max Wedges when they were new),
all the 413/426 Industrial blocks are preferable to standard production assembly line blocks.
But in my opinion, what I think is unique in this block is that it was cast in the same unique
mold as the NASCAR blocks that guarantee an extremely stout thick casting.
In the early 1990 Mopar Performance discover 6 Special original castings from their
early 70's Trans Am program in a warehouse in Ohio.
One of my friends at Mopar Performance (I will not name him here either) offered them all to me.
In our testing and use, we found them to be by far the best and thickest casting that we
have ever found. They are still currently running is four of our Stock/SS cars.
They are a significant reason for us being blessed with the success we have received over
the last 30 plus years. We have learned the correlation between block stability and thickness
and Horsepower production.
Just my .02 = For Free!
all the 413/426 Industrial blocks are preferable to standard block.
mold as the NASCAR blocks that generated an extremely stout thick casting.
One of my friends at Mopar Performance (I will not name here) offered them to me.
Very cool!!!
All these parts are from the estate of Gregg Luneauk (You can goggle Him)
who was one of the top Max Wedge Races and engine builders nearly forever.
He had done all the machine work on my cars for many years and in my opinion
one of the very best engine guys and racer who ever lived out here in the West.
He was a Mentor of myself and my boys as well as a beloved friend!
When I finally can, I will unload and survey everything. It will be a heck of a job
for me (Pushing 80).
The 426 Shortblock is 697 Casting 12/11/63
It says AAQA on the front. The pad is 426 TMP
and has valve notches on top of bore. Zero ridge or
taper and appears to have very little use. Max Wedge
crank with balance tabs and Max wedge rods.
I can not believe no one has even inquired on this shortblock.
Ten years ago it would have been worth twice this price.
Two 426 Standard 230 Blocks with no ridge and one 730 Standard 426
with VMP 426 on pad and AAQA on front and Valve notches on top of bore.
Standard and no ridge and honing still available.
They are now on Craiglist
