- 3:47 PM
- Jul 17, 2008
- South Jersey USA
did 11 inch rear drums come on 383 cars? such as Super Bees?........ I was under the impression this was a 440/hemi thing
My 69 RR has 11" drums all around, no PB, and uses a .8 ohm ballast resistor.
No they did not, they had 10x2.5" rears with disc. The only B and E body disc brake car that had 11x2"5" rears in 1970 was TA and AAR70 Road Runner 383 power disk had 11”x3” drums in back
Have seen 4 wheel 11" on early Chargers w/383. Usually a big rad and tow package type thingman, I was way off base![]()
Towing package will trigger heavy duty brakes. Had a 73 Charger SE 400Hp car with a towing package with front discs and 11" rear drums.Have seen 4 wheel 11" on early Chargers w/383. Usually a big rad and tow package type thing
Maybe my car was changed? It did have what I think was an E-body rear end (? - leaf springs forced onto not saddles about 1” to far out each side) when I bought itNo they did not, they had 10x2.5" rears with disc. The only B and E body disc brake car that had 11x2"5" rears in 1970 was TA and AAR
Isn't that the case on '67 on up11x3 front
11x2.5 rears
If 4 wheel drum brakes
'66 and upIsn't that the case on '67 on up
That's how my 66 is configuredIsn't that the case on '67 on up
