14" to 15"; what's required?
TT from NH
12:26 PM
NH
Probably a really silly question ... I want to go from a 14" rim to 15" on my 68 Coronet. Is there anything I need to consider other than finding a rim with the 5 x 4.5 bolt pattern? If I plan on upgrading to disc brakes, should I do that first? I guess in short I'm looking for advice in upgrading my wheel/brake situation and welcome all suggestions.
you can put 15 on no problem. Just make sure you get the same Back Setting on the rims if you buy new.
Stock-type disc brake conversions will fit fine with 15 inch wheels. If you go for oversize rotors and calipers, then should do your homework before buying wheels.
Thanks for your input!,
