0DegreeEngineer
Ammeter shows steady center under load and at idle a minimal discharge. These readings are from an under dah mounted voltage gauge, reads steady power coming off of auxiliary port on fuse box. Mechanical regulator at idle battery voltage changing from 12.8 to 14.3 while idling (Warm) slow change not rapid, without taking the hood off and setting my DVOM directly to the battery to confirm where should I start looking or is this just an overly sensitive gauge? Is my Mechanical regulator set to high?
