150 rallye dash with tach.
Grave digging an old thread. How much is this worth. Came out '71 charger.
what condition is the facia ( woodgrain ) in
It kinda sucks. Lots of bondo work and recoloring (bondo) to match. They fitted an aftermarket radio in it and vintage air controls. I wouldn't use it.
But I'm not a mopar guy. I don't know the availability of replacement parts.
Aside the new bezel per your description also It needs a new housing to get the radio and AC control supports ( they were cut ). We don't know if tach works, HOWEVER seems to be barelly used or allways protected from the sunlight due the redlines are not yellowed.
The only thing makes it kinda worthly is the tach. I don't think more than US$300
Bezel and housing can be found around. Some ppl uses to part out these assemblies. This will add around US$100-120 on the count
It all depends on how many folks need one and see the ad. You could get $500, you could get $75.
I wish someone would part out the OEM gauges. I want the tach to replace the clock in my rallye dash.
Classic Industries and Charger specialties (?) has repop ones. But if looking for a OE one, then have to look
I am building a resto-mod style 71 GTX, and I might not use the original tach cluster in liu of going with a custom setup. Still kicking it around and not 100 percent sure yet, but if you want to shoot me a PM so I have your contact info maybe we can work out a deal if you're still looking.
Radio cut. Ac has bondo in in it to fill the gap of the retrofit ac control. Other than that I guess ok. I used the knobs in the other dash. And moved the radio to the dash strip.
