172 tooth flywheel 426?? Starter question
INTMD8
9:41 AM
Lake Villa IL
Hello,
I was going to try and start the engine today and found that for some reason it has a 172 tooth flywheel. (and the starter is for a 130 tooth flywheel)
It's a 69 Charger with a 426 hemi.
Has a TKO 600, I believe a keisler bellhousing.
Looks like powermaster makes a 172 tooth starter for early hemi.
Think there is any chance that would bolt up and work or should I pull it apart and install a 130 tooth flywheel?
Thanks!
Well I ordered a mini starter from RobbMc so hoping that works out.
the 172 was to get a lower ratio with the non reduction gear starter
IDK maybe smaller than the old High Torque reduction gear starter
was there an ex manifold problem?
I do not remember
reduction gear mini starter should work well
Well looks like the 172 starter will not work as the bellhousing is not for the same. (so starter mounting pattern/location is different)
Looks like at this point I need to pull it apart and put a 130 tooth flywheel in it.
130 should still work with a permanent magnet gear reduction late MOPAR truck starter
Hemi's have 8 bolt flywheels. Make sure of what you have before you order flywheel.
