- 3:41 PM
- May 14, 2011
- On the Ridge, TN
Ladies and gents (and the rest of yas):
I've finally located an honest to God 18 spline A833 4 speed, apparently a '68 unit according to the numbers. It's fresh out of the transmission builders' shop and has had pretty much everything replaced supposedly.
Too much $$$, but oh well...
I've lined up a fellow who builds Mopars for folks and has a few of his own (including a '69 Charger R/T that is seriously nice, all the way up to the blower sitting on top of the 572 hemi!)
that has a two lift shop to do the actual transmission swapping for me.
That will include indexing the bellhousing.
Reminder: I have a '72 block 440, a '68 factory 11" big bearing cast (heavy!) bellhousing and currently a Centerforce Dual Friction clutch setup with less than 500 miles on it, along with an old worn-assed 23 spline of unknown origin from the early 70's (dual pattern on the tailshaft housing).
Question #1:
I need to fetch him some offset dowels obviously and figured I'd get a pair of each of the three sizes, then send back whatever ones he doesn't wind up needing.
Are these dowels the 0.5" diameter ones I see referenced on Summit's site?
Question #2:
As some of you may remember, I'm not particularly fond of the Centerforce Dual Friction clutch, especially in stop and go traffic (like parades, for example). I've gotten over the whole pedal position thing, but that thing is really an on-off switch sort of clutch and if you ride it any (like in traffic), it gets hot in a hurry!
The gentleman doing this work for me has a brand new McLeod disc of a more organic composition and I was thinking of just putting it in there instead of mine.
Will that work ok with the Centerforce pressure plate?
Question #3:
I'm going to pick up the "new" rebuilt transmission in the morning. I don't know really what to check when I do. I mean, short of pulling the side cover off there in the parking lot, is there anything much I can do to "inspect" the thing prior to forking over the loot?
Thanks!!
Ed
Question #1:
Question #2:
Question #3:
Thanks!!
Ed
