hgufrin
Hi -
My headlight motors do not work as they should. The motor will only rotate in one-direction. So I am trying to take apart and see what the problem is.
Step 1 - I melted/removed the hard rubber adhesive that holds the two halves of motor housing together.
Step 2 - I removed the "snap-ring" if that is what you call it. With a little twist the two halves come apart (see Pic #1 and Pic #4)
Step 3 - In Pic #2, this part was seized so I removed, cleaned-up, and now it rotates as it should
Step 4- In Pic #3, i removed the two long bolts (that I thought was holding internals in housing)
Question - how do I remove the windings, axle, commutator out of here? If I gently pull on the axle it will not come out. Do i need to cut the two 12v black wires?
Sure would appreciate your input.
Merry Christmas.
Merry Christmas.
