1966 Coronet Dash Lights
JimM
11:03 PM
Waterford,CT
Maybe someone can help me with this problem, I have no dash lights at all in this car. It was like this when I got it and the car had been parked for 20 plus years before that. All the fuses are good, the wiring looks good under the dash also. Do the dash lights run through the headlight switch as with some other brands? The fact that they are all out seems to rule out bulbs, I think. Anyway, your comments are greatly appreciated as always.
Jim M
Mine were like that in my 66. Took the headlight switch apart and cleaned all the contacts. Worked fine after that.
Headlight switch and even the bulbs should be checked and/or completely replaced. Also don't forget the bulb twist plugs that go into the printed circuit board...cr8crshr/Tuck
