Furyous
This car has had over 30k invested in it. It is together and driving but still needs tweaking as everything except for paint and body is new with less than 500 miles on it. This car was built to drive back and forth from Texas to GA and be able to roll on the highway. All the hard work is done. NADA in excellent condition is $119k but only asking $30k obo Only rust is in the lower quarters
. NO rust in pans or trunk. Center trunk has been replaced though.
Electrical:
All redone so everything works as it should.
Motor:
512 Stroker off of the warranty block that was in the car since 1967. Hughes custom grind camshaft, stealth heads, Performer intake, holley carb, tti ceramic headers and full tti exhaust. Mopar performance valve covers, milodon water pump and 440 source water pump housing. Custom aluminum radiator with dual custom electric fans. New starter, new alt, new distributor, new wires, new plugs, new orange box, new free flowing air cleaner. All balanced and is a 10- 1 motor.
Trans:
727 from Summit racing new, new 2200 convertor, new pistol grip race shifter.
Rearend: All rebuilt with eaton locker, 2:73 gears, back braced, complete Cal Trac setup including springs. This has not been adjusted yet so it will need that done.
Front End:
All new from rotor to rotor with PST kit.
Interior:
All new legendary seat covers with new foam and frames rebuilt. Door panels are still original and show well. Headliner and convertible top is new as well. The pump needs new hoses but have most. Goes up and down manually.
$30,000 obo and the car is located in Midland GA.
Electrical:
Motor:
Trans:
Front End:
Interior:
