1968 Dodge Charger Steering Gear
Charger Too
5:53 AM
Illinois
1968 Dodge Charger Steering Gear: The two mounting bolts on the right side went in the K frame and are tight. The mounting bolt on the left side will not tighten. The threads on the bolt are fine, not stripped. Any way to improve threads in the K frame? Thanks!
The right way would be to pull the box and repair that hole. Can you get at the threaded end? You might be able to get a nut on it if there is enough threads or a longer bolt. If you cant get to it then the box should be removed and the hole fixed.
