1968 Plymouth GTX
Well I got the right side installed with the chrome.
Still waiting for the new window crank handles to arrive.
Unfortunately, I had already installed the left side without the chrome, so I will need to pull that back off - again.
As I understand it, there is a narrow metal strip that is supposed to be between the door panel and the carpet. When i put my car together (I bought it without an interior), the strips came with the car, but there was not enough space here to have them at this spot. I never figured this out, so I left them out.
I noticed this on the other side as well. It is because I left too much carpet in that spot. When I trimmed the carpet on the right side, the panel fit much better.
It seems I remember two small strips of chrome, I will have to check my parts boxes. Thanks.
Here's are the pieces that I remembered were stored in a box.
Cleaned one of them up a bit to get a better look. Are these those lower trim pieces you mentioned?
Burlap and 18 gauge wire arrived today.
Decided to try installing the listing wire but only every 2". I noticed on the Legendary Video that don't use any listing wire at all.
This was the first attempt. I got a better game plan on each row, so it should go a bit easier when I get back to it tomorrow.
Also, wondering if I should get a new emblem for the back seat?
The backing appears to be simply be pressed on.
Hi, what did you use to tie the ends of the listing wires together. Mine look like they were tied with some type of rope, but it’s all disintegrating now.
I used the thin plastic coated clothes line rope because it lasts forever and it was about the same diameter as the original stuff.
Does anyone have a source for the proper size door lock knobs?
Every one that I ordered that said they were for a 1968 Plymouth GTX are all too big. When I install them I cannot move the lock at all.
My car was an early '68 model built in 1967, would that make a difference?
Too big in diameter or length?
If too long, cut bottom. Do you have the one that worked before?
It might be the trim ring on the sill opening. I had this problem with my '68 Hemi GTX, April build. When I bought the car, it had no rings on the openings, and lock knobs that were way longer than stock. I tried three different sets of trim rings, along with three different pairs of knobs. I couldn't get any combination to work. The best I could do was the knob binding when it was a little over half way down. I finally went with no trim rings, and the most stock appearing knob.
My '69 A33 GTX retained the original opening trim rings. I replaced the after market anti theft knobs with the first reproduction set I bought on eBay, and they worked. I did have to cut some plastic off the bottom to get the correct height. I installed NOS on Baby Blue in 1985, to replace after market knobs. They screwed in to correct height with no issues. Most restored GTXs I see today have knobs that are way higher than original. My current '69 has NOS knobs, and they sit low, about an inch above the sill.
Here is what mine looks like and the bottom photo shows the diameter of the stem. Car was manufactured in October 1967.
Diameter is too big.
From the other pictures posted it could be a combination of the wrong size trim rings (mine are very loose in the door, so too small) and the knobs being too wide at the top.
I will do so more digging into this issue. Thanks for the help.
