1968 Road Runner door glass
mchoate1
7:47 AM
Arizona
Need help on how to install the driver side door glass.....What goes in first,,,etc..? thanks
On my 68 Charger I put the door glass and quarter window assy together and then put the entire thing in the door as one assembly. It was the only way I could get it all to fit.
It wasn't as hard as it seems, just be very careful.
Thanks.....with the glass in the quarter track...when the front track (wing frame) was installed...it then went in the lower rear track.????....
P.S. How did you get it in the regulator ??..
I disconnected the rear track, but left it inside the door leaning up against the side, then inserted the window/quarter glass assembly. At that point I losely attached the three points of the quarter glass track assembly and set the door glass into it's regulator and put the pin in it. Then it was easy to just attach the rear window track again by pushing it onto the rear of the glass and sliding it up into place.
Hope that helps.
Thanks for the help on this.....Have never worked on one befor...Milton
