- 6:23 PM
- Aug 22, 2008
1969 383 shortblock, all race-grade machine work, 010/010 forged crank, oem beam polished/mag'd/shot peened rods, ARP wavelock bolts, TRW 2315 forged pistons, Speed Pro ductile/moly rings (.020/.018 end gaps), Clevite 77 bearings, balanced, brass core plugs, MP intermediate pump drive shaft, blueprinted and clearanced Melling std vol oil pump, windage tray, 187 oil pan, Lunati VooDoo 268/276 hyd cam and lifters (degreed in), Jegs 9way 3 bolt double roller timing set, clearances set: +.004 skirt clearance, .006" thrust, rod and main bearings +.002", -.002" deck, block ground/deburred/shot blasted/mag'd, cyls bored and honed/plateau honed w/BHJ honing plates, VHT Chrysler 'early blue' (turquoise) engine enamel, 440 source damper indexing tape, a great street engine with boss drillings for late '60s A-body engine brackets. If you're looking for a very good short block for your 67-69 DP A-body, this is it, $3000 firm, plus shipping. Located in Savannah, Tn. Interested parties pm me here, thanks for viewing...wb
