1969 Charger 440 RB Exhaust Manifold Studs and Nuts: Do I need to use Lock Washers?
robl72
12:24 PM
RI
Should I be using lock washers to attach my exhaust manifold to the studs?
The previous build used them but I noticed when I bought a new exhaust manifold stud/nut kit that it did not include lock washers.
Also should I be using Anti-seize or some other product on the studs?
Thanks for any help!
Never saw lock washers on any exhaust manifolds, or headers for that matter. I do like to use anti-seize a lot on stuff. I don't think it could hurt.
10-4 on the never seize, on any exhaust or aluminum. You’ll thank yourself if you ever have to take it apart.
Anti-seiz yes, lock washers no.
Thanks guys! I am going to settle anti seize yes and lock washers no....
The exhaust studs that go into the head need sealant on the threads so coolant doesn't weep past and leak.
I finally got lucky on something.... The studs that go into the heads stayed in when I removed the nuts, so I am good!.
I've also learned that anti-seize must be used on two stainless steel fasteners (nut & bolt) when used together.
