1969 Charger Tail light trim rings
vabchmopar
9:44 AM
arizona
Looking for pictures of how or what holds the trim rings on the rear tail lights of a 69 charger
The pins were somehow mushroomed over when assembled. Must of been a special machine or process.
I want to say I used a little jb weld or something similar. A little gob where the pins were
I was trying to avoid using any goop but that might be the way to go
Use an automotive panel bond. We use it for that exact application.
you're referring to these bezels right ? i had same issue , lost one about 20 years ago. finally found someone selling the side i needed.
i'm going to try the JB weld seam sealer & panel bond and say a little prayer just to be safe :)
