1969 Dodge Charger R/T 440 - "General Lee" Project -DUBAI-
Mr Z
9:40 AM
Hey all,
I decided to post about my 69 Charger on this forum, i usually post it on (Instagram: 1969Dubai).
Would appreciate to get tips and information about parts later on.
Car: Dodge Charger 1969 R/T
Engine: 440 Mopar Big Block 7.2L with holley
Transmission: Stock (Manual )
Things i need to buy:
Brake Kit Front & Rear: Still looking
Suspension kit: Still looking
Fuel Pump: Still looking
Fuel Tank:
Still looking
Engine Upgrade: Thinking about it
Transmission Upgrade: Thinking about it
Digital cluster ( Speedometer ) replacing with the old one.
Note: Hopefully this will be a daily used car.
Does anyone has an idea about a better Brake Kit Front & Rear quality for 69 charger
Dr. Diff has some decent stuff and stands behind what he sells.
Thanks for the pics, I suggest you to introduce yourself and your project in the welcome wagon, a lot of guys will watch you there and is a good start point for your questions, btw do you have the fender tag?
Will do :) and yes i have the fender tag i just need to find it in the box, i took it off while painting the car
What are you looking for, stock replacement, aftermarket big brakes?
No, im looking for a new brake system. The stock brake has less safety features comparing with the newer brakes (depends on what kind) if you know what i mean.
Check out a user named "invincibleextremes" on dodgecharger.com. He makes caliper brackets for different setups. Not sure on the pricing, but they are very affordable. I used 2014 Mustang GT calipers and 13" rotors on the front and 2014 Mustang GT calipers and 12" discs on the rear. I bought OEM takeoffs from ebay for around $150 per set. I was able to easily piece together a 4 wheel disc setup with hydroboost for around $700-$800.
View attachment 726838 View attachment 726839 View attachment 726840
Wow this actually looks great. 700-800$ pretty good to be honest. My budget for the brake kit is about 2000$ max
Thanks for sharing i will differently check them.
Good start there! I did the same as above, went with caliper brackets and Mustang Brembo brakes.
I used to live in Dubai, still miss that place..
Quick update:
Installed the brake kit front/rear + the QA1 suspension for both front/rear
I found out that i need to buy new ball joints :S
Engine/Transmission Done. needs testing now.
Do you have a build thread, if not you need to start one because that's looking whicked!!!:thumbsup:
:lol:
Great looking job so far @Mr Z ....looks like you might have some sand to compete with out there.
