TA726
- 5:46 AM
- Sep 19, 2018
1969 Dodge Coronet 500 Hardtop Super Bee Tribute Car.
Restoration started from the detailed underbody to exterior paint and is near completion.
Now selling with only a few details left to finish.
Runs, drives, stops, steers and sounds great!
A/C and heater have been deleted however, the original HVAC box will be included with the sale.
The restoration was started in Oklahoma which is where I bought it from and continued the work as needed once I got it home to Texas.
I've made every attempt to be as thorough as possible so please read details below on the vehicle and I will try to answer any questions you may have.
Overview
Drivetrain:
•Engine - rebuilt 383 big block (when I bought the car I was told it was original to the car but I do not believe it to be)
Engine has noticeable tick from top end, maybe lifter, maybe rocker adjustment - it was like that when I bought the car and wasn't too concerned about it.
•Transmission - New 727 automatic transmission with shift kit, high power clutch/plates upgrade by Keith at 727 Specialists.
2600 stall speed torque converter.
New Bouchillon Performance Kickdown / Carb plate, cable, and bracket.
•Rear - 8 3/4" rear end with New 4:10 Detroit True Trac center section.
*Will include an additional third member*
*I'm sorry but I don't have much in the way of specs on the rest of the drivetrain other than what is listed here*
Fuel:
•New factory fuel tank, sending unit and full length fuel line.
•Electric fuel pump.
Exhaust:
•Brand new complete exhaust; X pipe, Magnaflow mufflers and tail pipes.
•New factory style exhaust tips and hangers.
Cooling:
•New aluminum radiator and hoses.
•Flex-a-lite mechanical fan with shroud.
Charging/Starting:
•New voltage regulator, electronic ignition module, coil, and resistor.
•Spark plug wires.
•Positive and negative battery cables.
•Starter
•Battery and tray.
Chassis:
•Cleaned and painted underbody and frame rails with Chassis Saver black.
•K-Member reconditioned and painted.
•All new front-end suspension package including bushings, tie rods, lower control arms, upper control arms painted and sway bar.
•New rear leaf springs and shackles.
•New shocks and bushings.
•All new complete front disc brakes, new rear drum brake kit installed.
•New manual master cylinder with adjustable proportioning valve mounted inside the car.
•New parking brake and cables.
•All new brake lines and hoses.
•New I-Did-It tilt steering column.
•Front end alignment.
*Brakes do work however need to be further bled*
Body Exterior:
•Sunflower Yellow paint with Super Bee decal. Paint is very nice however is not perfect and does have some chips. Also seems to have some black particles in a few areas as if from overspray that should come out easily with a good detailer.
Body panels stand to be better aligned.
•New black vinyl top.
•New windshield and molding / gaskets.
•Brand new AMD front and rear bumpers (including brackets) and exterior lamps.
•Factory Super Bee tail lights.
•New exterior trim; emblems, wiper arms and blades, antenna mast & bezel. Door and trunk cylinder lock kits.
•Newly installed rubber bumpers, weatherstripping, window felt and body plugs.
*Window glass are all installed but need fine tune adjustment*
*Weatherstripping needs to be installed for the trunk lid (which I have) and for the left door jam*
*Right side hood hinge works but hangs up a little when closing the hood*
Body Interior:
•New factory wiring harness by MH.
•Reupholstered front bucket seats.
•Reproduction console, shifter, and shifter knob / button.
•New headliner and sail panels.
•New firewall insulation.
•New carpet (Dynamat sound deadener underneath the carpet)
•New dash pad.
•All new PUI Interiors front and rear trim panels, arm rest pads and bases.
•New plastic weather shields installed behind all four panels.
•Factory radio.
•Woodgrain steering wheel
*Rear bench seat needs to be restored with new foam and cover and installed*
*Rear package tray needs to be finished and installed*
*Horn button needs to be installed*
*Needs one arm rest pad and the glove box insert*
Clean title in my name.
The car is by no means a top notch show winner, however, it is very nice looking car that gets a ton of attention anywhere it goes as you can imagine.
Car is being sold as is.
Video can be seen here:
Located in Sugar Land, Texas 77479 (just outside Houston)
$28,500
Overview
Drivetrain:
Fuel:
Exhaust:
Cooling:
Charging/Starting:
•Spark plug wires.
•Starter
•Battery and tray.
Chassis:
Body Exterior:
Body Interior:
•New dash pad.
•Factory radio.
$28,500
