biomedtechguy
Accelerati Rapidus Maximus
- 9:03 PM
- Mar 28, 2014
- South Louisiana
Oh I have 6 years experience driving my Roadrunner that I am writing about with manual brakes. The first modification I made was a "Right Stuff"/Dr. Diff front drum to disc brakes conversion, BUT they have never been right for more than a few days or a week at a time. I've had a number of "ah-HA!" moments where a part or hose section or fitting was discovered and replaced and I just knew that was what was causing trouble all along...and then as always, soft pedal, pedal moving closer to the floor, and unreliable braking.The only non-power brakes I've driven are the manual 4-wheel drums on my '66 VW Bug. However, that is a far cry from the system you are installing. There definitely is a more mechanical-feeling connection with the VW's manual brakes than the other cars I've driven.
The master cylinder round plastic caps on the system Cass aka Dr. Diff sold me HAVE ALWAYS LEAKED, and he even sent out a pair of thicker caps that we thought may have fixed the problem, but NO.
The last time I thought a major problem was discovered, the hose that goes on the rear axle and has the metal junction block was the suspected culprit, I had it replaced and the lines bled again. Went and picked up my car and the pedal was high and stiff. I thought I had finally got it fixed, but over the next week, every day it got worse and worse.
So there won't be ANY part, piece, hose, or tubing from my existing system remaining in my car when the Wilwood goes in, and I expect it to be the PERFECT braking system.
