Hot or stone cold,the car won’t turn over no click no nothing,power on all accessories work,try it ten times or so then it starts fine and runs good,Car has stock distributors,elec.ignitiion,4spd all help welcome.thanks Pepper
As it turns out,I have two problems,the relay only works intermittently,also the ignition switch only works intermittently,bought ignition switch from year one a year ago it had about 70 or 80 starts before it failed,aftermarket junk.I appreciate your help thx. PepperI had the same problems with a brand new aftermarket ignition switch.
Great that you found it. Mine came from Megaparts iirc, don't know who's their supplier. I finally bought a good used original for the price of an aftermarket one, no problems since then.As it turns out,I have two problems,the relay only works intermittently,also the ignition switch only works intermittently,bought ignition switch from year one a year ago it had about 70 or 80 starts before it failed,aftermarket junk.I appreciate your help thx. Pepper
