SOLD 1970 Date coded 440 HP Engine and Matching 727 Transmission
Psycho Dad
12:10 AM
Indiana
Feedback: +12 / =0 / -0
IMAG0580.jpgFor sale is a 1970 440 HP engine and matching transmission. Everything is date correct for a 1970 B, E or C body built mid December 1969. Block, 906 heads, water pump housing, intake manifold, 4741s carburetor, starter, alternator, 879 & 865 exhaust manifolds and a NOS fuel pump are all dated between very late October through mid to late November 1969. Also included are a set of Six Pack rods and matching balancer. Engine is currently disassembled. The ID pad on the block is stamped F440 HP along with two "C"s. I believe the assemble date is: 12-8-69. The block is standard bore and will need machine work. Also have the matching 727 with the same VIN as the engine. Transmission part number is PK3410670L 3027 3555. $1700. Everything will need to be picked up. Parts are located in the Chicago area. I'm sure I've forgotten I few things but this should give you an idea of what is available. I'm helping a friend to sell a few of his parts but should be able to answer most any question.
PM if interested
For sale is a 1970 440 HP engine and matching transmission. Everything is date correct for a 1970 B, E or C body built mid December 1969. Block, 906 heads, water pump housing, intake manifold, 4741s carburetor, starter, alternator, 879 & 865 exhaust manifolds and a NOS fuel pump are all dated between very late October through mid to late November 1969. Also included are a set of Six Pack rods and matching balancer. Engine is currently disassembled. The ID pad on the block is stamped F440 HP along with two "C"s. I believe the assemble date is: 12-13-69. The block is standard bore and will need machine work. Also have the matching 727 with the same VIN as the engine. $1700. Everything will need to be picked up. Parts are located in the Chicago area. I'm sure I've forgotten I few things but this should give you an idea of what is available. I'm helping a friend to sell a few of his parts but should be able to answer most any question.
PM if interested
I sent you a PM for the Part number on the tranny, and the numbers on the pad of the Block. Still waiting on reply. Thanks,
Randy
Randy
F 440 HP
12-8-69
Two C's
I don't have the transmission part number yet. I'm helping a friend sell a few of his parts and I don't have immediate access to the parts. It will be a couple of days before I have the information.
