1970rt440
I ordered the following leaf springs from JEGS :
I used new shackles in the rear and using the stock hangers in the front of the spring. After installing the new leaf and new stock height rear shackles, the wheel hub has shifted towards the front of the car and the rear shackles are not sitting vertical what so ever.
I decided to start the driver side before reaching out here and the carriage to the new leaf spring pin is off about an inch from lining up. I finally caved in and am asking for help.
Thank you
312-P3690454
312-P3690455I used new shackles in the rear and using the stock hangers in the front of the spring. After installing the new leaf and new stock height rear shackles, the wheel hub has shifted towards the front of the car and the rear shackles are not sitting vertical what so ever.
Thank you
