Hemibird
Hey Folks ... I have been "Lurking" Here for years, and have gleaned some very valuable information. Thanks. BUT, this is my first post, and it is due to a strange issue that has popped up ... literally. I'm hoping someone with mre experience than I can Answer this.
The car - 1970 Hemi Roadrunner 4-Spd
The issue - There is a solenoid on the primary carburator(Back One), that lifts up to make contact with the throttle linkage, increasing to engine RPM. I'm assuming it it part of the automatic choke system. The solenoid expands fine, and when I pull the power wire, it contracts down, BUT, while powered, it never shuts off, causing the engine to race. I have backed off the contact screw ... only to have the solenoid expand further, and backed off more, and it expanded even further. Now, that idle adjustmen linkage screw, is backed all the way out, and the solend stays fully expanded when hooked up. Is there a sensor somewhere, or is it contained in the solenoid ... that allows this unit to function properly? My 68 Hemi has a manual choke, so this piece is non-existant on that car, therefore I can not compare or swap out parts to diagnose the probem.
Thanks in advance
Thanks in advance
