- 9:00 PM
- Mar 28, 2014
- South Louisiana
I am very happy with the alignment and overall performance of the new front suspension on my Roadrunner, which got a new K-member, and every other front suspension component replaced other than the center link, which is still factory. SPC is the only non-QA1 part, and that was for the great range of adjustments available.
Other than the very slightest "play" when the steering wheel is straight, and a fraction of an inch of turning the wheel left or right doesn't turn the car, the only complaint I have is changing lanes from say...a new layer of blacktop makes the lane yet to receive the new layer slightly lower, it "tracks" the car towards the lower road surface. I will comment about a road surface that has low U shaped areas where the tires run in the lane once I get to drive on a road like that, as I suspect it will want to "track" along those low spots too.
Anyway, is/are there any parameters of alignment that help counteract "tracking"? What are they?
Thanks for ANY comments!
Here is the alignment numbers for the current setup I just got done:
