CharlesUSF
New Member
1970 383 RoadRunner Project - All original parts, straight body/frame, needs good home. Currently rolling chassis project, Motor Tranny not in car, motor turns over freely. Frame/sub frame solid, cowl tag correct and visible. Tons of stainless. $5,500
Below the pictures I have decoded the Fender Tag:
Car comes with the following:
- Title
- 383 original engine - Factory 383 headers
- Automatic 727 transmission
- Original Hood
- Factory fiberglass grill shell and original stainless steel
- Back driver / passenger quarter windows
- Original 15' mags with tires
- Starter
- Power Steering
- Brakes
- Front rear very nice chrome bumpers
- Carburetor
- Steering wheel
- Front / Rear lights and turn signals
- Ton of misc. parts Stainless Steel parts. Door handles, wipers, etc too many to list.
Chuck 727-000-0000
c----------------------------m
EDITED BY STAFF. PLEASE SEE THE FORUM RULES( http://www.forbbodiesonly.com/moparf...t.php?f=13&a=2)
BEFORE POSTING AGAIN. NO EMAIL ADDRESSES OR PHONE NUMBERS.
Fender Tag Decoder Results
CODE OPTION DESCRIPTON
LINE 1:
'e63' '383cid 4bbl Magnum 335hp (STD w/Road Runner) (Orange Paint) (NA w/H51)'
'd32' '3-Speed A-727 TorqueFlite HD Automatic Transmission' ''
'rm23' '1968 - 70 Road Runner 2Dr Hardtop' 'Also used for 1970 Super Bird'
'n0g' 'Engine: 383 ci 8 cyl 4 bbl High Performance' 'Model Year: 1970' 'Assembly
Plant: St. Louis, MO'
'138663' 'Serial Number' 'Should match VIN'
LINE 2:
'ff4' 'Lower Body Plymouth: Lime Green Metallic' 'Lower Body Dodge: Light Green
Metallic'
'ef8' 'Upper Door Frame Color: Ivy Green Metallic' ''
'a07' Build date: 'October 07'
'104755' 'Factory Job Number' 'Factory # should not match VIN'
LINE 3:
'ff4' 'Upper Body Plymouth: Lime Green Metallic' 'Upper Body Dodge: Light Green
Metallic'
'a01' 'Light Package (NA w/A13)' 'Ashtray, Trunk, Glove Box, Map, & Ignition
Switch Lamps, Hood Mounted Turn Signals'
'n51' 'Maximum Engine Cooling' ''
'j25' '3-speed Windshield Wipers (STD w/A04,E74)(Required w/N96)' ''
'l31' 'Hood Mounted Turn Signals' ''
'm21' 'Drip Trough Molding' ''
LINE 4:
'r11' 'Music Master Solid State 2 Watt AM Radio (STD w/A04)' ''
- Title
- Original Hood
- Starter
- Power Steering
- Brakes
- Carburetor
- Steering wheel
Chuck 727-000-0000
LINE 1:
LINE 2:
Metallic'
LINE 3:
Metallic'
LINE 4:
