Slipjaw
Looking for 1970 rr post passenger cleat side door glass
Clear... I've seen it listed also as coupe postPost or hard top? Clear, or tinted. Actually, not sure if there is a difference between post or HT...?
I've seen the AMD, but what is ECS website?He stated POST in both the subject and his posting. Post glass is about an inch shorter in length.
I have one, with a sandblasting mark from a jack *** with the window down and key lock out! Where I practiced my polishing technique and removed it fairly well. Not perfect, but drivers quality. You can also buy new from AMD or ECS (complete with date codes) for fairly little money.
Thanks!Don't start that argument again over here.. LOL.. A Post car is a Coupe or Sedan. Hardtop = no post.
http://www.ecsautomotive.com/
I beg to differ... only needed a grinder for the passenger side!!the amd glass does not fit....
Same curve, same glass thickness as the OE. Finish on the edges less than desirable (and I had to grind the front edge to get it close enough to the slider/lock pin hole) but they both work just fine.
