SOLD 1971 Satellite Drag car
RON71rr
10:53 AM
Port Alberni B.C. Canada
Feedback: +0 / =0 / -0
I found another car , that I just have to have, so this must go !
1971 Plymouth satellite Drag Car, has 72 fenders. Runs in the 12's, 1/4 mile. Mild 440, 727 with 3500 stall, Cope Racing reverse manual valve body, billet low/reverse servo, modified accumulator,billet kick down lever, 8 3/4 4:56:1, 742 case U.S car comes with the border paper work if you wanted to ever register it, will be sold with bill of sale. $7800.00 PM me if interested. THANKS Located West Coast B.C. Canada
More info :
stock suspension with comp engineering shocks all 4 corners.
adjustable pinion snubber
8 3/4 4.56:1 , 742 case, stock axles, stock 71' B-body width.
1967, 727, stock internals with CRT reverse manual valve body 22x, billet low / reverse servo, modified accumulator, 3500 stall converter, B&M pro rachet shifter, line loc.
78' 440 stock short block with comp 509 cam, TM7 edelbrock intake with 850 Demon carb. , 906 heads with very light porting, Hooker super competition 2" primary headers, MSD Pro Billet distributor, mini starter, SFI flex plate (out of cert., but not needed for the times the car currently runs) moroso electric drive for water pump, large factory rad with electric fan.
Cowl and wiper hole are filled, steel hood has inner structure removed.
Just converted the front to disc brakes, A-body spindles , rotors, new calipers, pads, hoses, aluminum master cylinder from Rick Ehernberg (MOPAR ACTION, editor), has 11 inch drums in rear.
body is good, has 72' road runner stripes, I would call the paint job a 20 footer, but very presentable. has had passenger floor pan replaced, drivers side has a few holes. Driver side front frame has an older repair, looks like the fairly common battery acid leak from back in the day, it is solid, tech inspectors had no problems with it, it is better than a lot of the ones I have seen.
new Optima battery , trunk mounted
28 x 10.5" MT ET drags, radials on the front on polished centerline replicas, 3" studs front and back, rigid valve stems on all wheels.
Rci seat, with current belts, new this year
Rci fuel cell
passes tech to 11.50 et
Will also throw in a Comp engineering 8 point roll bar kit, and a spare 440 block, if you want to build a bigger engine ! First $5500.00 cash takes it !
if you r willing to part out let me know intersted in a few parts
Don't part it! Man, where was this deal when I was car shopping?..
Love the car Ron, looks like a good deal.
I still want it !
Ron,
I want it. I'm working on the logistics of it.
Do you have a trailer at your disposal?
Again, can you get it over the border for me?
I don't have a passport and would like to come back to the US :eek:
I'll PM you later, I'd like a buddy of mine to look over the cars specs first..
Thanks,
MIKE..
I wish I had the room for it!!!!
