1972 charger
billfury
10:54 PM
staten island ny
Feedback: +0 / =0 / -0
I'm parting a 1972 charger.
Clean roof. $200
Clean dutch panel $150
1971 440HP motor carb to oil pan no pulleys or accessories
8.75 rear $200. drum to drum.
8.25 rear $100 drum to drum
323 sure grip 489 case $350
323 non sure grip 489 case $100
Windshield $100
Rear glass $75
Door glass $40
¼ glass $35
71 rear bumper good core $75
71 taillights one broken tab but will not affect it. Wiring needs some work. $100 for the
Pair
72 charger taillight buckets with no lenses r/s has a rotted socket l/s has a crack in the corner. $25 pair
71-72 rear bumper brackets $50 for the pair
71-71 charger front bumper brackets $50 for the pair.
72 charger right side fender $200.needs some work but not rotted out.
318 radiator- $75
Non A/C heater box. Two tabs broke can be fixed. $25
Heater cables $25
Rear valance no cutouts nice $100.
Non A/C dash frame complete except for the harness & cluster. $100.
Dash frame only for A/C car $75
Rear seat need new covers good cores $25
Left & right blue upper door panels $40 pair
6 bow for headliner $50
4 bow for headliner $40
Complete set of bucket seat seat belts needs cleaning.$100
71-72 charger vapor canister with covers. This is the one in the wheel well. $50 complete
Front drum brake set up complete with manual master & prop valve spindles drums $75.
All prices are negotiable
Thank you
I’ll ship. The big stuff like the rears and roof should be picked up, but I will work with the buyer if they really needed it.
sold 8.75 rear.
6 bows sale pending
323 sure grip sold
front & rear bumper brackets sold
updated list
8.25 rear $75 drum to drum
Windshield $100
Rear glass $75
Door glass $40
¼ stationary glass with all hard wear $35
71 taillights one broken tab but will not affect it. Has a hairline crack in one of the lenses. Wiring needs some work. $75 for the Pair
72 charger left side fender $100.needs some work has rust behind the headlights on the inside. Dog leg solid. Can send pictures
72 charger right side fender $100.needs work will send pictures
318 radiator- $75
Heater cables $25
Non A/C dash frame. $100
Left & right blue upper door panels $25 pair
Complete set of seat belts needs cleaning. For bucket set ups. $100
71-72 b-body fuel tank $25
71-72 b-body filler neck with bracket $25
I have body bolts & miscellaneous clips for 71-4 B-Bodies.
Set of door hinges from 71-4 b-body. Good cores $40 71-72 B-body hood hinges $40 pair
wondering if you had a deck lid for a 72 charger and is the radiator and the windshield still available for purchase thank you justin
Added more stuff
Windshield $100
Rear glass $75
Door glass $40
71 rear bumper good core $50
318 radiator- $75
Heater cables $25
Rear seat need new covers good cores top & bottom $25
71-74 charger rear upper panels black real nice $50 pair
71-74 B-body A pillar panels green & black nice $40pair
I have body bolts & miscellaneous clips for 71-4 B-bodies
71-74 B-body door hinges good cores $40
1974 B-body 440 dual snorkel air cleaner real nice shape. $150
71-74 B-Body dash pad cores $50 each
manual steering box $75
73-74 charger non SE grills. Has a crack but nothing missing $25 pair.
71-74 B-body AM radio nice with knobs and bracket. $50
73-74 B-body rear sway bar with only one plate. $50
73-74 B-body shock plates. $40
71-72 charger ¾ vinyl top chrome moldings $40
71-74 B-body lower windshield corner chrome pieces $25 pair
440 water pump housing $25 each
383-400 torker $75.
Upper control arms came off a 72 charger with disk brakes $25 pair.
Auto gage RPM $20
Auto meter sport comp RPM $25
E-body steering wheel only $25
71 heater valve nice shape $20
hi- would that radio be compatible with a '69 coronet dash? i'll try to find out, but if it's still available, i'm definitely interested...
