WTB 1972 Coronet Frame Rail
willem
12:35 AM
The Netherlands
Hi there,
I'm looking for a piece of subframe for a 1972 Dodge Coronet (wagon). I have a rusted rail on mine (see https://www.forbbodiesonly.com/moparforum/threads/hole-in-sub-frame.182598/#post-911412069) and am looking for a replacement part. The location you can see in the picture below. The frame in the picture is not actually the same frame i have, but i put this in to indicate the location of the part i need.
@moparmarks He might be able to help. Also to help that front rail is the same on 71-2 B-bodies and not wagon specific...
If it's the passenger side
I have 2 of them
Just give me time
To dig out and take pics
As I have been thru this before
My question is do you have a container
To send it over
or are you planning to ship it there ?
To ship it there will be very expensive
Ok
The drivers side I have is junk
Maybe MoparMarks might have something for you.
I have found a 1973 Charger frame rail. Will this fit on a 1972 Coronet?
I don't think it will work
front subframe suspension is different between 71-72 vs 73-74
Nope. I have some of those, 73/4.
71-2B and 70-4E will work.
You have to be careful with the e-body rails as they are different in 73-4. The rails are the same dimensions but the bumper bracket holes are not the same as 71-2 B & E they require relocating welded mounting nuts in the frame to use them...
