rhorton
I came across a REALLY nice shape 1975 440 with a cast crank. It runs incredible. I'm going to look at using it in a b body project car. Any suggestions on what to do with it to make it a bit more "usable"?
it had AC so I assume its going to need a bunch of crank/AC bracketry to get it to work, Anyone got some suggestions on a complete "front end kit" to make it work?
Does the tailshaft of a 68 b body bolt right onto the back of the 1975 RV 727 trans?
Should I jsut leave the cam that is in it since its going to cost me $200 to get another 20hp?
What should the compression be on that 1975 motor?
Is it even worth it to put headers on this thing? thsi is the first "budget build" I've done and i'm curious if it even makes any sense to do it.
The car is set up for a 22" radiator. If I have a shroud for the 22" one I have should I even bother trying to modify the core support it to work with the 26" radiator I have from a 68GTX?
Thanks as always guys.
