1978 Cordoba Heater cable
4:35 AM
houston
I need the cable that runs from the heater select to the mix box, What is the part #???? car has A/C....Thanks!!!
Are you talking about the big black box behind the glove box under the dash? If so, those are vacuum tubes going to it. Or, are you talking about the heater control valve mounted under the hood with four heater hoses connected to it?
If you're talking about the cable that controls the underhood valve you're SOL on a Cordoba. BUT, I pulled the innner "wire" from the housing and replaced it with the inner from a universal choke cable. It has to be pretty long and the ones you'll find at Autozone or Advance won't cut it, I went to NAPA and got a 6' long one they say is for a tractor.
