1978 cordoba
78 Cordoba
Here are the two wires too???? one is on the compressor and the other behind the alternator..see pic's i have looked for a loose wire and cannot find the connection too....Any Ideas?????
Thanks!
78 cordoba a/c wires
Hello,
Here are the two loose wires see pic's I have looked for the other connections...the rest of the a/c components look to be ok but want to get the compressor going and start from there....
Thanks!
On vacation and have been cleaning the Cordoba, Got my courtesy light lenses but do they pop on or is there a mounting wire where the four holes are? I took the lighted vanity mirror out and found out the reason it isn't working is that a copper switch that makes contact with the other switch when you flip it open, the mounting plastic is broken so i have re-glued and hope that resolves that...still have to replace the valve cover gaskets and the master cylinder..when the weather is cooler i hope soon, the gauges do seem to work as the low fuel red light came on when i had it running...so much to do.....
They just pop out and pop in. Nothing special holds them.
It's all the little things to do that keeps me busy all the time. But I tell myself it must be fun, that's why they call it a hobby!
Put a new master cylinder on, now i have better Brakes!! still have too replace the valve cover gasket and will try too do that tomorrow...did wash the Cordoba the first time since I had it delivered in July, The Vanity mirror is now working and put back in the sun visor....
