FOR SALE 1986 D-250
s/w theo
6:43 AM
Bucks co. Pa.
Feedback: +4 / =0 / -0
This truck was sitting in a warehouse for almost 25 years. Under 97,000 miles, NO ROT ANYWHERE. It's a 318, factory NP435 4-speed & Dana 3:54 geared rear truck. It had been in a front-end accident & was never put back together. I see NO frame damage & ALL front sheet metal was MIA & not to be found along with all the under-hood wiring. I have all the necessary front sheet metal needed to finish it but no under-hood wiring harness. I rigged up a temporary ignition system (It had an ESC system originally) & it fired RIGHT UP, (I first checked that it wasn't locked-up, removed the dist. & primed the oiling system, installed new plugs, wires, cap & rotor, new fuel & air filters & ran it on gas from a gallon jug under the hood) no smoke, no ticking, no exhaust leaks, nothing. The pictures say most everything & I will get any more you want & answer any questions. The truck is in my yard & I'm in Fairless Hills, Pa. 19030 Zip code. The Reading utility body on back is SOLD. $3500 takes it home. I now have the title in MY name.
