SOLD 1994 Ford Ranger XL 302/AOD/4:10
44070dart
5:46 AM
right behind you
Feedback: 5 / 0 / 0
on ebay... 1994 ford ranger... this truck has only 64,600 miles on body, will have a few more as I'm driving it. Buffalo NY ..$4900.
https://www.youtube.com/watch?v=rX0P...ature=youtu.be
Ford Ranger XL has a 1993 Mustang 302 block.. .030 over, KB pistons 10:1..Trick Flow heads,170cc twisted wedge heads, 60 cc chambers ..Trick Flow + .080 hardened push rods..Compcam guild plates, Compcam 1.6 roller rockers, Trickflow stage 2 track max cam with .542 intake lift.. Edelbrock RPM airgap intake ..holly carb ..MSD distributor and MSD 6AL ignition box with Blaster coil.. MSD 8.8 wires..Headman headers ..expensive March aluminum serpentine belt bracket set, along with March aluminum under drive pulley set.. aluminum radiator with 16" electric fan.. electric fuel pump. Lokar braided stainless throttle and kick down cable... Mickey Thompson cast aluminum valve covers.. ARP head bolts, intake bolts and rocker arm studs.
1993 Mustang AOD trans 4R70W 1 piece input shaft, 2" overdrive hub and band setup, Transco shift kit, shifts tight. B&M shifter, Trick flow finned cast aluminum trans pan, Radiator and aux cooler.
1995 Mustang Cobra 8.8 rear end converted to leaf springs, Ford racing carbon clutch pack, Ford racing 4:10 ring and pinion, Strange Summit racing 28 spline axles, 4 wheel power disc brakes, leaf spring traction bars, differential / pinion girdle.
Kazera 10" wheels with very good BF Goodrich tires 235 x 50 x 18 ..Removable steering wheel with power steering... Tach with shift light and oil, temp, and volt meter gauges. Switches for power, fuel pump, fan, ignition. Rear vent window. Good lift tonneau cover. Shaved door handles with door poppers, and push button start. Interior seats/carpet in good shape, as is the glass. Tailgate solid, works fine.
Nice SOLID driver truck, not a race truck, not show quality, but gets looks at cruise night. Has a few scratches, but not any rust, above or below. Solid frame, good solid bed and interior. Fun truck runs/drives very well, will cruise all day without heating up in traffic. Great street manners on 89 octane, overdrive great for the highway. 65 mph at 2200 rpm's. A bit loud with Flowmaster racing mufflers. A LOT went into this truck. Gas gauge doesn't work and radio works when it wants to
