mjb765
First--I am just making sure on this one...if you ground the wire coming off of the fuel tank sending unit and the gauge reads full, but only reads 3/4 when connected--even if the tank is full, then I am guessing the sending unit is bad?
And second...The ammeter is bouncing between either side of the +20 line on anthing over 2000 rpm. Checked voltage at the battery and it's 13.4 at idle and sometimes can hit 15v when I rev it. When I say bouncing--I don't mean just moving back and forth--this thing is violently wiggling, or jumping. Just happen to replace the battery today since it failed load test...but that didn't change the gauge movement. Any ideas?
