2006 Ram 2500 Cummins belt tensioner
QuickBpBp
8:39 PM
SE PA
Ok you guys who repair your trucks yourselves like me… Over the years I have had these tensioners go bad and eat alternator bearings, A/C compressor bearings and now my sons went bad on his ‘06 Ram 2500 Cummins and ate the water pump. I assume that is what does them in as EVERY time the tensioner was froze. So today I tore it apart and put it back together since it wasn’t raining or blowing 50mph. Lol. Anyway I had to put a pipe on it to break it free to get the belt off. Pump wasn’t bad but putting the new belt back on SUCKED. So I wanted to ask when do they typically go bad? I have over 130,000 now on my 2017 Ram 2500 should I throw one on there? Thanks in advance.
They're cheap.
Take your belt off and run it through it's range, if it has a sticky point or if the pulley is crunchy, toss one on.
I replace it every time I replace a belt.
Me too. Getting the new one wound in is fun. Once you get it on the crank, the rest is not too bad. Crank is the hard part.
