Hi
Just picked up a 2011 5.7 gen 4 and would like to install it into a 78 dodge magnum which is a big block car. I got the hemi without any harness or intake. I would like the easiest way to go with this so I was thinking a carb and 727 T/F.
It does have the solenoids from VVT on the top as well. Do I have to remove them and block it off?
MSD has an ignition system (6013) for the conversion would that work on the gen4?
I realize the tranny would have to be switched to a small block, but do I have to change K-member to a small block one as well? It has the later model type with spool mounts.
Since I wasn't given any wiring harness I am not sure of what I would need since I am going with a carb. I was looking for an intake but choices are not too plentiful. I looked up edelbrock but saw only dual quad not single. Mopar perf has a single plane, as well but way more $$. I will probably use the stock exhaust manifolds if they fit
Any help on this would be greatly appreciated.
Thanks
Thanks
