wilsonlar1
For anyone out there that has made this change, is there a noticeable difference changing from 3.23 to 3.55 gears? I will be installing a sure grip at the same time.
I'm looking for a setup that will give me a better jump off the line for the rare race. My engine is a 383 that is built pretty strong and I think the gears are holding it back.It helps. Had 8.75 w/3.23's open rear hit the gas at slow roll big trail of smoke. Went to 3.54's in a Dana w/suregrip then could put the power down that made difference. Last summer put 8.75 in w/the 3.23's after 30 years of sitting made noise pulled the 3.23's now I had a 4.10 put that in big jump. Instead of a chirp 1st to 2nd (auto trans) would spin the tires. If you drive any distance to much gear.
My application is an occasional race but mostly cruising. I do like to get from one stop light to the next, quickly. I'm just wondering if the difference between the two is enough to invest in.You will not go as fast but you will get there faster. Gas mileage wise I have gotten better with lower gears all depends on your application.
I did that gear swap. I think the best way to describe it is;For anyone out there that has made this change, is there a noticeable difference changing from 3.23 to 3.55 gears? I will be installing a sure grip at the same time.
Not sure what torque converter I have. I haven't gotten inside to see what's in there.What torque converter do you have? A switch from a stock converter to a good performance converter will improve acceleration more than a switch from 3.23s to 3.55s. But yeah, you need a sure-grip in there.
