318 poly column shift to a833 4 speed
jeff deakins
1:57 AM
daphne alabama
Was looking in to doing this if possible.Curios if anyone
has any experience with this.
Jeff
Transmission to bellhousing patterns are totally different if your going from the 3spd to a 4spd. I know of no polys that came with a 4spd.
The proper 340 bellhousing may get you there.
Trucks came from the factory with a 4 speed on a poly. Yes it is doable what year poly?
Someone started a thread on this a few days ago
I've done it in a 62 fury 2 door wagon
big heavy three speed and early driveline
we used an iron bellhousing but I do not remember out of what
may have had to change the clutch disc
it is doable
If the poly is post 62 it is very simple really, Pre-62 not so much. The 62+ 318 poly uses the same flywheel as any internally balanced small block with 10.5" clutch (273 used a smaller clutch). Don't forget that the 360's and later 340's are externally balanced.
