318 poly plug wires
318polara
5:21 PM
Boise, id
Can someone direct me to a set of plug wires that will fit a 318 poly? It's for a '63 Dodge, if that matters. I haven't had any luck at parts stores. I am inevitably handed wires for an LA 318 or who knows. Suppose I could go the custom route if needed, but it would be nice to get a direct fit out of the box. Thanks in advance.
I couldn't find an off the shelf set so I had some custom made by Eagle here in Australia for the same price as their 318 LA kit. I've cut and made my own once before and vowed to never do it again.
I bought a set of cut to fit msd wires from the parts store. The part number of the set they sold me differs from the part number msd shows as fitting. I think the boots are a little longer than they need to be. Otherwise the wires are plenty long enough for the poly. There is a website that sells poly plug wires that have the correct date codes on them for around $100 if I remember correctly. That seemed a little overkill to me and I'd prefer performance wires to correct appearance wires. I've only installed one plug wire at this point though. I've got an electronic ignition upgrade to do so I haven't cut the remaining wires. Only got the first one because I had a plug wire fall apart in my hand.
I have a set from NAPA that fit right on the poly 318 in the 64. Blue wires not black.
