318 power steering pump w/ 440 brackets possible?
spcedwards214
6:09 AM
South Carolina
Is there a way I can simply use my sb 318 pump with 440 brackets? PS setup is expensive and I have a pump readily available. Is there a bracket kit I can buy and swap over to my pump? Thanks
Based on the lack of response I'm guessing not. My car has a bastard set-up using the original 318 pump/bracket on a transplant 440 but there is some misalignment I'm trying to correct. It hasn't thrown a belt yet but using anything other than stock and you are taking your chances.
pumps are the same, it's the mounting brackets that are different
Might try contacting Steer and Gear in Columbus Ohio. those folks are pretty knowledgeable and may have just what you need. steerandgear.com
