318 Push Rods - 302 Heads
TopBanana72
8:01 PM
Ohio
I'm putting '85 302 heads on my 72 318. I'm using the original 72 rocker shafts and rockers. Can I use the original push rods?
I believe you can because your not changing the engine deck height, or camshaft... its just a head swap.
If all the bolt holes for intake, block, exhaust manifolds, are the same ... should be no problem
That's my two cents. FWIW.. :)
HR20
